2 laptops... deleted both databases for try out (so clean)
laptop 1: star rated several mp3 folders from within vdj, automatically written to files ( is suppose )
transferred to laptop 2, several rated files were unrated!
batch reloaded all tags , nothing...same
so some rated mp3's are still written in database only not into the file and this sucks for people using several laptops etc.
this is STILL not good after all this time...! PLEASE FIX ASAP this is major
thanks
thanks
geposted Fri 22 May 15 @ 5:12 am
Find an mp3 file that didn't save it's rating and open it in tag editor. Confirm it has no rating tag, then set a rating and write the tag for that one file.
If it doesn't save the tag then upload that file so we can see why it's not saving.
I don't see this sucking that much for people using multiple machines, since the sensible thing would be to sync the databases so that you get all the non-tag data too. My backup machine and backup drive have exact replica databases which are automatically synced between machines.
geposted Fri 22 May 15 @ 7:11 am
long live Robomirror.
geposted Fri 22 May 15 @ 7:30 am
SBDJ wrote :
Find an mp3 file that...
As Scott said, you should also check the filetype of the songs that don't save the rating. Not ALL filetypes support rating...
geposted Fri 22 May 15 @ 7:31 am
Some info about tag support.... This is my own research I still need to test more file types - http://www.virtualdj.com/homepage/wickedmix/blogs/5246/id3_Tag_Support_in_VDJ8.html
geposted Fri 22 May 15 @ 11:47 am
this has been advertised as a version 8 improvement so it could be considered a moral duty to finish the job and actually fix this. personal opinions about whether it sucks or not are... well quite irrelevant imho. In my personal workflow I can say that I want the tags to be hardcoded into the files and not into the database. A hardcoded native file rating system can be considered backup safer than database based I think. I will check again and send the files to adion if they aren't written well. I have his mail. Thanks
geposted Fri 22 May 15 @ 5:56 pm
obviously mp3 files only. I might be weird but not quite that stupid.
co developed and beta tested for Roland, Cakewalk, Presonus and Hercules. requested to be a beta tester for vdj8 long time ago. If only....
geposted Fri 22 May 15 @ 5:59 pm
I'm not sure I'd say it was 'advertised'. If you are able to replicate and thus assist us to find the bug, then yes, we will fix it if possible.
You offered your personal opinion; is no counter opinion allowed?
geposted Sat 23 May 15 @ 4:45 pm
myes obviously any opinion is allowed. However it kind of felt like your opinion tried to marginalise / trivialise my point. Which is it should work (especially after all this time) And you offering a workaround doesnt quite change that. However it wasn't meant to be unfriendly. However sometimes I feel that devs dont really care if it doesn't mess with THEIR workflow, which I think isn't the way it should be. Anyway I will try to find the specific files, send them over and am willing to cooperate constructively and in a positive way.
geposted Sun 24 May 15 @ 3:44 pm
It is not unbelievable that something is not working after no matter what amount of time if nobody ever mentions or notices that it is not working.
We can't fix things that we don't know are broken.
geposted Tue 26 May 15 @ 3:42 am
Dear Adion, not quite.... please check out my januari 25th post about this. (As you may recall we had a conversation about it.) I failed to send the files to you but will do now. But I mentioned it in quite an intense post as you can read below. ;-)
http://www.virtualdj.com/forums/197833/VirtualDJ_8_bug-report_Forum/This_______drives_me_INSANE______O____database_rating_doesnt_work____whats_up_devs___.html?search=mp3%20rating&page=1
geposted Tue 26 May 15 @ 4:42 am
For a year I've been saying that VDJ 8 does not remember cue points --
http://www.virtualdj.com/forums/187139/VirtualDJ_8_bug-report_Forum/Denon_3700s_x1600_issues.html?page=4
geposted Wed 27 May 15 @ 5:25 pm
correction: It actually works ok after rechecking. I will rectify this in another post. My sincere apologies for this...!
geposted Thu 28 May 15 @ 5:33 am
